Ergebnis 1 bis 11 von 11
    Standard [OPB] so you want some pots shots, no problem
    now 6 pots altogether
    insulated and installation is way different than the first one
    cuz you gotta think about the space between two cards..so the screws can be like 1st one that long
    [img]http://www.cbbocteam.com/opb/6pots/6pots01.jpg[/img]
    the other side:
    [img]http://www.cbbocteam.com/opb/6pots/6pots02.jpg[/img]
    whole system completed
    [img]http://www.cbbocteam.com/opb/6pots/6pots03.jpg[/img]
    night shot
    [img]http://www.cbbocteam.com/opb/6pots/6pots04.jpg[/img]
    I still can press start botton and reset on the RE
    [img]http://www.cbbocteam.com/opb/6pots/6pots05.jpg[/img]
    now wait for me get up and grab DI, I have 40 L LN2
    [img]http://www.cbbocteam.com/opb/6pots/6pots06.jpg[/img]
    wish me luck
    Avatar von merl1n
    25.01.2007
    Impflingen RLP
    1.173
    Nice setup kevin...keep pushing we will wait of your results
    15.10.2007
    Hochstadt
    565
    very nice setup. might i ask, which power supply you use?
    and you wanna bench with these six pots all on your own?
    It looks awesome, kev!
    Very nice! I will see them in action!
    AF-hwbot-team Avatar von hansl.petre
    06.05.2007
    Zittau
    1.386
    you are a crazy freak - wanna see action too
    Besucht auch meine Alben hier im Forum
    realy nice, keep pushing
    ** psu, either use toppower 2kw or silverstone zm 1200
    Andi, you will need to have shorter screws on one set of that pots and you might need to fix the screw, it's so hard to get in throught the holes 4 together when the screws are loose
    I had to un screw the mounting plates and fasten the nuts to fix a bit so I can mount on the 4870x2
    I Understand, Multi GPU is not always the best , thats a compromise.
    Nice setup,will see running it Did you demuonted the heatpipe from the Rampage? How do you cooling then the potential transformers?
    15.10.2007
    Hochstadt
    565
    i guess the board will be cold enough especially if he's benching in a box
    no need for a heatpipe on the mosfets
    Avatar von merl1n
    25.01.2007
    Impflingen RLP
    1.173
    common kevin, dont let us wait longer...i remember you wanna bench yesterday!?
