Ergebnis 1 bis 19 von 19
    Team OCX Avatar von clon22
    04.08.2008
    35
    Standard Mini Test Report : Avantium Tri-Channel DDR3 2000mhz 9-9-9-24 3x1GB Kit : :D
    I ordered this set some 2 weeks back.
    Received them 2 days ago.
    Its also my first set of Tri-Channel memory.
    Rated at 2000mhz 9-9-9-24 @ 1.65v.
    I ordered it before the rating label was changed.
    Its actually 1.65v.
    [IMG]http://i76.photobucket.com/albums/j37/clon22/Avantium_DDR3_2000mhz/pic_3.jpg[/IMG]
    My bench equipment : (Just bought a few days back)
    -i7 920 w/TR Ultima 90i
    -Intel DX58SO (The only board I could afford.)
    -Maxtor 160GB Sata
    -Corsair TX750w
    [IMG]http://i76.photobucket.com/albums/j37/clon22/DX58SO/set_2.jpg[/IMG]
    I'm still not very familar with the board's dividers.
    Sometimes it doesn't boot for me.
    So I'll stick to 2:10 for the time being.
    Set to 1.66vdimm in bios.
    8 instance 32m 1T(9-9-8 ) was a breeze.
    [IMG]http://i76.photobucket.com/albums/j37/clon22/DX58SO/i920_200x20_tri_1000_998_hyperpi-1.jpg[/IMG]
    [IMG]http://i76.photobucket.com/albums/j37/clon22/DX58SO/i920_200x20_tri_1000_998_hyperpi_sp.jpg[/IMG]
    9-9-8 1T was good to go too.
    (At least not before my processor gets too hot.)
    [IMG]http://i76.photobucket.com/albums/j37/clon22/DX58SO/i920_200x20_tri_1000_998_prime.jpg[/IMG]
    Only managed 211bclk from my 920 yesterday. HT was off.
    (Till i fiddle around more with the board.)
    So I got 1056mhz @ 1.74v(bios)
    [IMG]http://i76.photobucket.com/albums/j37/clon22/DX58SO/i920_211x20_tri_1056_999_spi32m_HTo.jpg[/IMG]
    Tweaked settings alittle.
    Same 1056mhz 9-9-8-21 @ 1.74v(bios)
    [IMG]http://i76.photobucket.com/albums/j37/clon22/DX58SO/i920_211x20_tri_1056_998_spi32m_HTo.jpg[/IMG]
    For some benching, 8-8-7 1T @ 2000mhz is good too.
    1.86v(bios)
    [IMG]http://i76.photobucket.com/albums/j37/clon22/DX58SO/i920_200x20_tri_1000_887_spi32m_HTo.jpg[/IMG]
    Removing the heatspreader was a breeze too.
    Even though the thermal pad had full contact,
    they glided off the chipsets easily with a slight nudge.
    No need to worry about the chipsets ripping off.
    Replacing it was simple too.
    Maybe more manufacturers should use this instead of the sticky ones. :
    [IMG]http://i76.photobucket.com/albums/j37/clon22/Avantium_DDR3_2000mhz/chipset_1.jpg[/IMG]
    Anyway, its using Samsung HCF0 chips.
    [IMG]http://i76.photobucket.com/albums/j37/clon22/Avantium_DDR3_2000mhz/chipset_2.jpg[/IMG]
    That's about all.
    I believe they should still scale higher.
    First, I need to learn how to use my board.
    Thanks to everyone for reading.
    Avatar von tAk
    Birsfelden, Schweiz
    5.058
    Received my kit today. (3x2GB Vers.)
    Hope to get the same results as you.
    THX for the review.
    mFg tAk
    Game: Core 7i 980x @ ?GHz | EVGA X58 Classified E762 | 6GB Corsair Dominator GT 2000C8 | 4 GTX 480 | Intel G2 80MB SSD & 2 500GB Samsung F1 + 1TB Samsung F1 | Win7 Professional | Dell U3011 | TT1500W
    04.08.2008
    35
    Thanks.
    And I think yours will even be better.
    04.08.2008
    35
    Sorry if I sound stupid.
    But I really spent a long time trying to get 21x multiplier.
    At one point in time, I even thought that leaving it idle for some time,
    I might, just might see it change to 21x.
    So i just stared at CPUz and task manager...
    i realised it wasn't going to happen...
    Only until I enabled speedstep.. (after trying out many stupid settings..)
    I finally saw 21x in windows.
    Haha.. I feel so dumb..
    In bios : Speedstep on, HT off
    Vcore 1.5v
    QPI 1.65v
    vdimm 1.78v
    (1056mhz 9-9-8-21 1T)
    [IMG]http://i76.photobucket.com/albums/j37/clon22/DX58SO/4435_1056_998_32m.jpg[/IMG]
    Nice results!
    ya, very easy cas8 @ 2000 and the point is no bloody money to spend like Corsair GT
    [IMG]http://www.ocxtreme.org/opb/x58teach/42g3d06.png[/IMG]
    04.08.2008
    35
    They do above 2100mhz 8-9-8 easily.
    [IMG]http://i76.photobucket.com/albums/j37/clon22/DX58SO/4427_1054_898_32m.jpg[/IMG]
    I'm bclk limited(i think).
    Definitely able to scale higher.
    Avatar von tAk
    Birsfelden, Schweiz
    5.058
    Wow, nice.
    You need a Core 7i EE.
    mFg tAk
    04.08.2008
    35
    Hey, thanks alot.
    But i7 EE, too expensive for me.
    Nice!
    Then save your money to buy one
    Corsair Staff Avatar von Bluebeard
    08.06.2007
    36
    But we are hitting 2000C7 @ 1,65V with the GTs and these are 3x2GB as you can see here
    And anyway Kevin, it´s nice to see that you always try to compare and catch up with your stuff (like you did on Newegg Forums before regarding the Team-Group modules) with the best out there - honouring for us
    BTW What´s your QPI/VTT voltage in XMP to hit the 2000C9?
    Geändert von Bluebeard (17.12.2008 um 10:52 Uhr)
    Bluebeard, I appreciate that your input here buddy
    as I discuss with Oskar, QPI (or you wanna call it VTT) somehow (not much)
    also depends on the motherboard,
    as my case, I just got my Rampage II extreme "rma" back from Newegg,
    my previous r2e when running 2000 8-8-8(or 999) I need 1.6v for sure, but the newer one is only 1.45v
    and this, you don't wanna say this qpi is too hight huh? you know this only about 1.48 v real
    [IMG]http://www.ocxtreme.org/opb/12gb/12gbcas91tcpuz.png[/IMG]
    Geändert von Onepagebook (17.12.2008 um 20:33 Uhr)
    04.08.2008
    35
    For me, on my board, 2000mhz 9-9-8-21,
    QPI is @ 1.4~1.425v in bios.
    Anyway, yeah, 2200mhz 9-9-9-24 1T
    http://valid.canardpc.com/show_oc.php?id=465089
    [img]http://i76.photobucket.com/albums/j37/clon22/DX58SO/2200mhz_99924_194v_cpuz.jpg[/img]
    08.06.2007
    36
    cpuz screens are nice - show us superpi 32M or anything testing stability
    faster latency then means higher QPI/VTT for Core i7 if I am right...
    NOt really Bluebeard
    NCI memtest 3.8 1000%
    [IMG]http://www.ocxtreme.org/opb/dfix58t3eh8/stability/2002kcas9981t1kp.jpg[/IMG]
    partial close up details:
    [IMG]http://www.ocxtreme.org/opb/dfix58t3eh8/stability/2002kcas9981t1kpa.jpg[/IMG]
    [IMG]http://www.ocxtreme.org/opb/dfix58t3eh8/stability/closeup.jpg[/IMG]
    [IMG]http://www.ocxtreme.org/opb/dfix58t3eh8/stability/closeup2.jpg[/IMG]
    Hmm i must change my sys when i see these Results.....
    @clon22 how many you payed for the kit?
    04.08.2008
    35
    Thanks.
    Sorry, was busy the past week,
    Today's Christmas Eve,
    found some time to do some testing.
    I think my kit does 1100mhz CL8 fine.
    sub timing were very loose, but i'll try tighter.
    [IMG]http://i76.photobucket.com/albums/j37/clon22/DX58SO/4610_1097_89821_32m.jpg[/IMG]
    04.08.2008
    35
    I luv these stick very much.
    There is some info here :
    http://www.awardfabrik.de/forum/showthread.php?t=5271
    post #23
    I got the 3x1gb kit at this price too.
    Avatar von tAk
    Birsfelden, Schweiz
    5.058
    How much VTT do you need to hit 1000MHz with cl8?
    Btw I got my system up and running yesterday (920i, R2E, 3x2GB). I seems that the CPU can't handle a higher Uncore. I am not able to hit 2000MHz on the memory, even with a high VTT an lower/higer BLCK (143,166,200).
    What batch is your CPU?
    Greetings tAk
