Ergebnis 1 bis 22 von 22
    BenchTec UK
    04.08.2008
    30
    Standard Crucial Ballistix Green 6GB DDR3 review
    Introduction
    Crucial sell RAM. Lots of it. As the retail arm of Micron, they have had access to some of the most popular enthusiast-level DRAM ICs for years and their Ballistix and Ballistix Tracer line aimed at overclockers and gamers has built up a solid reputation for quality and performance.
    Crucial have released 3 and 6GB tri-channel kits for I7 and have re-vamped their Ballistix Tracer line for gamers. There is now a wider choice of colour, so colour-co-ordination between RAM and motherboard is now much easier. Crucial have kits in the following colours: Black, Yellow, Green, Blue and Red. The Green, Blue and Red kits have matching LEDs to give attractive and VERY eye-catching displays when the RAM is active. The LED patterns have also been developed for the tri-channel kits and are genuinely worth watching and are worringly hypnotic! Gone are the multi-coloured LEDs of old- the RAM looks more mature and concentrated now but has lost none of its ability to turn heads.
    Undergoing the review treatment here is a 6GB kit of PC12800 RAM in Green, to match the DFI board being used as a base. The RAM comes in the standard unobtrusive cardboard box.
    [IMG]http://i2.photobucket.com/albums/y38/K404/DSCF0085-1.jpg[/IMG]
    [IMG]http://i2.photobucket.com/albums/y38/K404/DSCF0087-2.jpg[/IMG]
    [IMG]http://i2.photobucket.com/albums/y38/K404/DSCF0094-1.jpg[/IMG]
    [IMG]http://i2.photobucket.com/albums/y38/K404/DSCF0103.jpg[/IMG]
    [IMG]http://i2.photobucket.com/albums/y38/K404/DSCF0108.jpg[/IMG]
    [IMG]http://i2.photobucket.com/albums/y38/K404/DSCF0121.jpg[/IMG]
    [IMG]http://i2.photobucket.com/albums/y38/K404/DSCF0129.jpg[/IMG]
    [IMG]http://i2.photobucket.com/albums/y38/K404/DSCF0130.jpg[/IMG]
    [IMG]http://i2.photobucket.com/albums/y38/K404/DSCF0136.jpg[/IMG]
    [IMG]http://i2.photobucket.com/albums/y38/K404/DSCF0137-1.jpg[/IMG]
    [IMG]http://i2.photobucket.com/albums/y38/K404/DSCF0138.jpg[/IMG]
    Its hard to capture the shimmer that comes off the heatspreaders when the RAM is placed in bright light. It looks FANTASTIC!
    Heres a 2 1/2 minute video the RAM showing the LEDs through startup, load and shutdown.
    http://www.youtube.com/watch?v=TQEXurV7Rig
    Getting System Specific
    With the release of Intel I7 technology, the goalposts have shifted compared to Intels 775 socket when it comes to squeezing RAM performance. With the memory controller built into the CPU, the link between the vDIMM and the vIMC/ vQPI/vUnCore means that high-voltage operation is no longer as "safe" as it used to be.
    The voltage difference between vDIMM and vQPI can be 0.5v maximum to be safe. Depending on the reliability of the motherboards voltage labelling in BIOS and the actual delivery of voltage to the components, skirting around this 0.5v limit can end in tears via a dead CPU. Given that an elevated but fairly sensible vQPI is around 1.45v, that means that around 1.85-1.90v can be given to the memory, which is an important difference compared to the 2.2v reguarly pumped into DDR3 RAM in 775 systems for benchmarking.
    Seeing as Crucial RAM predominantly (but not exclusively) uses Micron ICs which love voltage, this could have an effect on the performance of the RAM when pushed and rival ICs such as Elpida Hyper have made their way into high-performing tri-channel kits for I7. Crucial arent going to give up their place in the market though, not that easily. Some other tri-channel Ballistix reviews have revealed Samsung HCF0 chips under the heatspreaders.
    Stock latencies and a surprise
    LEDs are meaningless if the RAM doesnt perform. The stock rating of 800MHz 8-8-8-24, 2T @ 1.65v is fairly pedestrian and there are plenty of kits out there offering tighter timings or higher MHz. That wont put an overclocker off though. Something that Crucial have NOT advertised here is that the kit has an XMP profile loaded that offers 7-7-7-24 operation at 800MHz with 1.65v!!!! Thats a big boost to keep quiet about! Its mentioned nowhere on the packaging, the sticks or on Crucials website. I didn't catch on until I
    loaded up the SPD tab in CPU-Z for screenshot validation... typically after i'd tried and tested 7-7-7-24 timings at 800MHz and thought i'd found free performance!
    BenchTec UK
    04.08.2008
    30
    System setup, test notes, assumptions and drawbacks.
    Motherboard: DFI X58 EH6. The X58 and FET heatsinks were checked for contact quality and thermal paste was replaced with Arctic Ceramique where appropriate.
    CPU: I7 920 C0. Watercooled.
    GPU: 512MB 9800GTX+ (The 512MB is important when dealing with RAM mirroring)
    O.S.: Windows 7 RC1 64-bit and XP Pro 32-bit
    Tests: Memtest 86 and SPi32M.
    RAM performance is closely tied to the CPU now as opposed to a capable motherboard, these results may not be achieveable by just anyone with an I7. Performance consistency, even within the same CPU batch is hit and miss. I believe my CPU to have a fairly capable memory controller, although its BCLK limit is fairly average at around 215MHz. Conversely, people with more capable CPUs may find this results easy to beat.
    Two low-speed 80mm fans were positioned over the RAM at all times.
    Absolute maximum performance limits were not sought, but rough numbers that most users should be able to acheive (subject to the points raised above.) There is scope for performance differences between kits, so I belive its the fairest way to present results.a QPI voltage was set at 1.44v for all tests. CPU voltage was adjusted as necessary for the clockspeeds but the CPU multiplier was kept fairly low to remove MHz as a possible bottleck.
    RAM and Uncore are closely connected in I7 chips. Uncore speed (derived from multiples of the RAM speed) is MINIMUM 4x the RAM MHz so if the RAM is at 1GHZ, the Uncore speed is 4GHz.
    Not every chip is capable of such frequencies so some might buy this RAM (or other high-performing kits) and not be able to use it at default speed due to a CPU limitation.
    Windows 7 RC1 is the only 64-bit OS I have access to and due to software compatability I was not able to run as many stress tests as I would have liked. Despite being a synthetic app, Memtest should show up any cracks in RAM stability.
    Despite the relatively low number of results posted, that does not mean there were not a lot of results discarded along the way as the RAM was tightened up. Memtest benching takes a long time and I do not have an unlimited time budget!!!
    Going over 950MHz resulted a loss of stability or unreliable behaviour. I encountered a sitaution where one RAM channel was dropped from detection upon startup. BIOS and Windows Task Manager reported a 4096MB RAM volume and there have been other users reporting similar problems at high RAM speeds. I believe this is either the first sign of instability or a limit in the IMC. I did not carry out any testing when this occured as it would be inappropriate for the purpose of this review
    I do expect readers of this review to have a basic understanding of I7 behaviour. If anyone is truely stuck, PM me and i'll do what I can do help.
    Memtest
    As always, I will not test at Crucials rated spec (subject to being aware of the stock spec!) I trust their quality control.
    From a basic spec of 800MHz, 8-8-8-24, 2T @ 1.65v I was hoping to be able to find extra running options without resorting to higher vDIMM values. I had aready "found" 7-7-7-24, 1T to be stable at 1.65 before I realised there are XMP profiles loaded. However, even the XMP profile sets a command rate of 2T, so being able to move from 2T to 1T without increasing any voltages was a plus point. Moving on from this, I was able to tighten up the tRP to 6 without any trouble, to give 7-7-6-18, 1T at 1.65v.
    [IMG]http://i2.photobucket.com/albums/y38/K404/800MHz776-181T165v.jpg[/IMG]
    Despite trying with higher voltages- up to 1.80v, I was unable to get the computer to POST with the CAS or tRCD set to 6. I have a feeling this is a BIOS limitation.
    Aiming now at higher MHz, I found 850MHz 7-8-7-18, 1T to be fine at 1.75v. I was slightly disappointed that I couldnt hold tRCD or tRP to their -7 and -6 latencies respectively much over 800MHz, even with 1.80v.
    [IMG]http://i2.photobucket.com/albums/y38/K404/850MHz787-181T175v.jpg[/IMG]
    Moving on again, 900MHz and on to 933MHz were no problem at 8-8-7-18, 1T at 1.65v This did impress me as it overtook higher-binned products. Stability tailed off quickly after 933MHz and I chose not to push it took hard as for true 24/7 stability there should be some breathing space left in the RAM.
    [IMG]http://i2.photobucket.com/albums/y38/K404/900MHz887-181T165v-1.jpg[/IMG]
    [IMG]http://i2.photobucket.com/albums/y38/K404/933MHz887-181T165v.jpg[/IMG]
    BenchTec UK
    04.08.2008
    30
    SuperPi 32M
    SuperPi32M only uses 600MB of RAM, so cannot be considered any kind of stability tests for people who buy this RAM to actually utilise it! However, it is a popular benchmark and this IS a benchmarking site after all! The SPi32M testing will also include higher-voltage testing seeing as its a competitive benchmark and sprint performance is acceptable.
    850MHz 7-7-6-18, 1T, 1.75v. MHz higher than this were more stable with tRCD and tRP loosed off by another clock cycle.
    [IMG]http://i2.photobucket.com/albums/y38/K404/850MHz776-18175v.jpg[/IMG]
    900MHz 8-8-7-18, 1T 1.65v
    [IMG]http://i2.photobucket.com/albums/y38/K404/900MHz887-181T165vCPU36.jpg[/IMG]
    970MHz 8-8-7-20, 1T, 1.75v. Higher than this, the board was more than likely to POST in dual-channel. Results were not persued in this state for reasons mentioned above.
    [IMG]http://i2.photobucket.com/albums/y38/K404/970MHz887-201T175vtrichannel.jpg[/IMG]
    Something else that should be added- a 2T command rate was tried but the maximum MHz ceiling was not lifted and the dual-channel behaviour over ~970MHz was still present. Seeing as, for this setup anyway, the RAM can be maxxed out at 1T I chose not to include 2T results, but as a rough guide, 2T adds ~4-5 seconds to SPi32M compared to the equivalent 1T
    settings.
    Conclusion.
    I was slightly disappointed that the RAM could not match some top-shelf rival parts in regard to CAS 6 operation, but given the difference in price, along with the difference in expectation, I wasnt heart-broken. Its entirely possible its BIOS-related anyway.
    The RAM has its niche market due to its appearance and is able to offer an excellent boost over stock for the overclocker, however, Crucial really have to push the spec of their kits. They seem determined to make this RAM look, on paper, as average as possible!
    Having useable performance 170MHz over stock at stock voltage and tighter-than-stock timings is genuinely impressive!
    As for prices....
    Tri-Channel RAM pricing is currently pretty random, I suspect in part due to the different ICs available- Samsung, Elpida and Micron.
    6GB 800MHz kits range in price from £64 to £180 depending on timings.
    6GB 933MHz kits range from £98 to £247.
    If the Crucial stock spec of 800MHz 7-7-7-24 1T is considered, whilst not being the cheapest kit able to offer those latencies, it is still cheaper than many rival kits that have slacker timing sets. Once overclocked, its value for money is increased quite a bit. The LED display, despite obviously adding cost to the RAM does not cripple its value for money in any way. Crucial still have no competitors for this selling point.
    I have no problem recommending this to people as Crucial (as far as I know) do not limit their RAM to make a higher binned part look more tempting for benching. The parts are quality and are backed by a lifetime warranty.
    My thanks to Joan @ Crucial for letting me review these despite how long they've been on the market!
    Geändert von K404 (17.06.2009 um 13:23 Uhr)
    BenchTec UK
    04.08.2008
    30
    Reserved for any future testing I do or anything else I discover about this RAM
    Thanks for sharing this review!
    All green looks good!
    What is with 1000Mhz @ Cl9 maybe?
    A-Team
    Avatar von Faxe
    10.08.2007
    A-schaffenburg
    1.720
    Thanks 4 the Review! Nice one!
    But i miss pictures of the leds in action
    PC: i5-750 3.6GHz | Asus P7P55D | 8GB G.Skill Ares DDR3-2400 | Gigabyte 280X OC | Corsair CX500 | Lian Li PC-A12B
    HC: Samsung UE55JU6450 | Samsung BD-C5500 | Harman Kardon AVR 151 & HKTS 5 | XboxOne 1TB | PS4 500GB
    BenchTec UK
    04.08.2008
    30
    I can get to 1000MHz Cas 8 ok but its in dual-channel mode. Anything over ~970-970 ends up that way I think its an IMC limit
    I was hoping the video would take care of that but I can take some pictures of the LEDs too if you want
    A-Team
    Avatar von Faxe
    10.08.2007
    A-schaffenburg
    1.720
    Yay, thx! Can you do it in Wallpaper Resolution (1680x1050)?
    Avatar von KvD
    04.03.2007
    Berlin-Tempelhof
    3.164
    looks soo sweet @ DFI
    thx for the review, ich love the green ballistix
    nice review thank you for sharing this results! that is a nice looking green. looks perfect on this DFI board
    The Ballistix Tracer DDR3 Line with the blue, Red and green would be the only reason to go for DDR3, but I think I stay with my Tracers and Lanfest anyway- thanks for the excellent pictures and wonderful review
    BenchTec UK
    04.08.2008
    30
    Thankyou very much guys!
    I dont think I have the right lighting or camera gear to get wallpaper-quality pictures at that res but i'll see what I can do.....
    Avatar von tAk
    Birsfelden, Schweiz
    5.058
    Wow very nice review!
    They look good an perform well...nothing more to expect.
    Greetings tAk
    Game: Core 7i 980x @ ?GHz | EVGA X58 Classified E762 | 6GB Corsair Dominator GT 2000C8 | 4 GTX 480 | Intel G2 80MB SSD & 2 500GB Samsung F1 + 1TB Samsung F1 | Win7 Professional | Dell U3011 | TT1500W
    A-Team
    Avatar von Faxe
    10.08.2007
    A-schaffenburg
    1.720
    @K404
    Ur pics in ur first post are telling me something different Lovely Pics, some of them Take ur time, i can wait
    @websmile
    /sign Only reason for DDR3.
    Nice rev What did you paid for?
    BenchTec UK
    04.08.2008
    30
    In the UK, its £133 direct from Crucial. I wish they were on the shelves of more shops, not that many e-tailors stock them
    pleas some pictures when it is dark and the computer is running
    A-Team
    Avatar von Faxe
    10.08.2007
    A-schaffenburg
    1.720
    I already asked him
    BenchTec UK
    04.08.2008
    30
    Hey. I took a few pics and uploaded them. The sun was still out and my camera does best in good natural light but I have massive depth of field problems and I cant move my bench table to a better place
    http://s2.photobucket.com/albums/y38/K404/
    I'll try another batch when its darker but I think they'll be worse.
    IF any of the pics appeal to you, just go for it. Reference me somewhere if you want, but im not fussed.
    K
    A-Team
    Avatar von Faxe
    10.08.2007
    A-schaffenburg
    1.720
    Thanks, but we need a pass to see them
    Avatar von Hyperhorn
    27.04.2007
    839
    Good review, well done!
    Over two months ago I did get the same kit, but unfortunately one stick was DOA, so there was no possibility to perform a Triple-Channel-review. Well, the CPU I had on had at that time sucked pretty hard MC-wise, so it doesn`t matter that much.
    Two points I have to agree with you are
    - eye-catching is just the right keyword, how they start flashing around when you power up the system (btw. the DOA-dimm stopped even there after 1-2 sec.)
    and
    - Crucial doesn`t really care about the power of their ICs at all. It`s even much worse with the cheap CT3KIT25664BA1339 with D9JNM, rated for DDR3-1333 CL9 which can you can easily push over 900 MHz with tighter latencies also...
