    04.03.2010
    25
    Standard i5 670 & ASUS P7P55D-DELUXE Motherboard 2D review
    I just recieved the ASUS P7P55D-DELUXE board, it doesn't sport the features of the P7P55D-E such as USB 3 and 6gb/s transfer
    but for mid range board it perfomed great. This board definatly has the overclocker in mind i was easily reaching 250 bclock
    and managed to push the ram frequency to 2200mhz at 8-8-8-24 out of my Corsair Dominator 2000mhz c8 DDR3 2x4 GB Kit
    ( cpu-z did not read cas latency correct ).
    [IMG]http://img30.imageshack.us/img30/3719/sdc10657x.jpg[/IMG]
    [IMG]http://img714.imageshack.us/img714/6753/sdc10660.jpg[/IMG]
    [IMG]http://img715.imageshack.us/img715/2218/sdc10664.jpg[/IMG]
    [IMG]http://img715.imageshack.us/img715/7051/sdc10667i.jpg[/IMG]
    [IMG]http://img714.imageshack.us/img714/3575/sdc10668.jpg[/IMG]
    [IMG]http://img705.imageshack.us/img705/3923/sdc10669a.jpg[/IMG]
    [IMG]http://img706.imageshack.us/img706/7233/sdc10670l.jpg[/IMG]
    Board Features
    CPUIntel® Socket 1156 Core™ i7 Processor/Core™ i5 Processor/
    Supports Intel® Turbo Boost Technology
    ChipsetIntel® P55 Express Chipset Memory 4 x DIMM, Max. 16 GB, DDR3 2200(O.C.)*/1600/1333 Memory
    Dual Channel memory architecture
    Supports Intel® Extreme Memory Profile (XMP)
    *Hyper DIMM support is subject to the physical characteristics of individual CPUs. Some hyper DIMMs only support one DIMM per channel. Please refer to Memory QVL for details.
    **Refer to www.asus.com or this user manual for the Memory QVL(Qualified Vendors Lists). Expansion Slots 2 x PCIe 2.0 x16 (single at x16 or dual at x8/x8 mode)
    1 x PCI Express 2.0 x16 slots (at x4 mode, 2.5GT/s)
    2 x PCI Express 2.0 x1 (2.5GT/s)
    2 x PCI Multi-GPU SupportSupports NVIDIA® Quad-GPU SLI™ Technology
    Supports ATI® Quad-GPU CrossFireX™ TechnologyStorage Intel® P55 Express Chipset built-in
    6 xSATA 3.0 Gb/s ports
    Intel Matrix Storage Technology Support RAID 0,1,5,10
    JMicron® JMB363 PATA and SATA controller
    1 xUltraDMA 133/100/66 for up to 2 PATA devices
    1 xSATA 3Gb/s port (black)
    JMicron® JMB322 (Drive Xpert Technology) :
    - 2 x SATA 3.0 Gb/s ports (navy blue and gray)
    - Supports EZ Backup and SuperSpeed functions
    *Drive Xpert function is available only when the hard disk drives are set as data drives. LAN Dual Gigabit LAN controllers Realtek® 8112L / 8110SC Gigabit LAN controller featuring AI NET2 and Teaming
    Audio VIA® VT2020 10-Channel High Definition Audio CODEC
    - Absolute Pitch BD192/24 featuring ENVY HD
    - DTS Surround Sensation UltraPC
    - BD audio layer Content Protection
    - Supports Jack-Detection, Multi-streaming, Front Panel Jack-Retasking
    - Coaxial / Optical S/PDIF out ports at back I/O IEEE 1394 VIA® 6308P controller supports 2 x 1394a port(s) (one at mid-board; one at back panel) USB 14 USB 2.0/1.1 ports (6 ports at mid-board, 8 ports at back panel) ASUS Unique Features ASUS Hybrid Processor - TurboV EVO
    - Auto Tuning, TurboV and Turbo Key
    - TurboV Remote
    ASUS 24 Hybrid Phase Design*
    - T.Probe Technology for Active Cooling
    - 16+3 Phase Power Design
    - 100% Ultra Long Life Japan-Made Solid Capacitors
    *24 Hybrid Phase = 16+3 Phase x T.Probe
    ASUS Hybrid OS - Express Gate
    ASUS Xtreme Design
    ASUS Exclusive Features
    - ASUS Drive Xpert
    - MemOK!
    - ASUS EPU
    ASUS Quiet Thermal Solution
    - ASUS Fanless Design: Heat-pipe solution
    - ASUS Fanless Design: Stack Cool 3+
    - ASUS Fan Xpert
    ASUS Crystal Sound
    - ASUS Noise Filter
    ASUS EZ DIY
    - ASUS Q-Shield
    - ASUS Q-Connector
    - ASUS O.C. Profile
    - ASUS CrashFree BIOS 3
    - ASUS EZ Flash 2
    - ASUS MyLogo 2
    - Multi-language BIOS
    ASUS Q-Design
    - ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
    - ASUS Q-Slot
    - ASUS Q-DIMM
    Overclocking FeaturesPrecision Tweaker 2
    - vCore: Adjustable CPU voltage at 0.00625V increment
    - vIMC: Adjustable IMC voltage at 0.00625V increment
    - vDRAM Bus: 81-step DRAM voltage control
    - vPCH: 2-step chipset voltage control
    - vCPU_PLL: 4-step reference voltage control
    SFS (Stepless Frequency Selection)
    - PCI Express frequency tuning from 100MHz up to 200MHz at 1MHz increment
    - Internal Base Clock tuning from 80MHz up to 500MHz at 1MHz increment
    Overclocking Protection
    - ASUS C.P.R.(CPU Parameter Recall)
    Back Panel I/O Ports 1 x IEEE 1394a
    2 x LAN(RJ45) port
    8 x USB 2.0/1.1
    10 -Channel Audio I/O
    1 x Clr CMOS switch
    1 x PS/2 Keyboard (Purple)
    1 x PS/2 mouse port (Green)
    1 x Coaxial S/PDIF Output
    1 x Optical S/PDIF Output Internal I/O Connectors 3 x USB connectors support additional 6 USB ports
    1 x IDE connector
    7 x SATA connectors
    1 x IEEE 1394a connector
    1 x CPU Fan connector
    1 x Power Fan connector
    2 x Drive Xpert SATA connectors (navy blue and gray)
    2 x Chassis Fan connector (1x4-pin, 1x3-pin)
    Front panel audio connector
    1 x S/PDIF Out Header
    1 x CD audio in
    1 x 24-pin ATX Power connector
    1 x 8-pin ATX 12V Power connector
    System Panel(Q-Connector)
    1 x TURBO_CON header (for TurboV Remote)
    1 x MemOK! button
    1 x Power on switch
    1 x Reset switch
    BIOS 16 Mb Flash ROM , AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS, ASUS EZ Flash 2, ASUS CrashFree BIOS 3
    ManageabilityWfM 2.0,DMI 2.0,WOL by PME,WOR by PME,PXE Accessories 1 x TurboV Remote
    1 x 2-port USB and eSATA module
    ASUS Q-Shield
    1 x ASUS SLI bridge connector
    User's manual
    1 x UltraDMA 133/100/66 cable
    6 x SATA cable(s)
    2 in 1 Q-connector
    Support DiscDrivers
    Anti-virus software (OEM version)
    ASUS Update
    ASUS Utilities
    Form Factor ATX Form Factor
    12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
    Test Setup:
    Asus P7P55D-Deluxe motherboard
    Intel i5 670 cpu (batch L937B954)
    Corsair Dominator 2000mhz C8 DDR3 2x4GB Kit
    Corsair HX-1000w psu
    Ocz vertex 64GB SSD
    Ati HD3850 gpu.
    @ Air testing
    [IMG]http://img689.imageshack.us/img689/1153/sdc10677h.jpg[/IMG]
    [IMG]http://img715.imageshack.us/img715/8649/stockwprimeair.jpg[/IMG]
    [IMG]http://img689.imageshack.us/img689/360/spistockairv.jpg[/IMG]
    Everest Report :
    Memory Read
    CPU CPU Clock Motherboard Chipset Memory CL-RCD-RP-RAS Read Speed
    Core i7 Extreme 965 3333 MHz Asus P6T Deluxe X58 Triple DDR3-1333 9-9-9-24 CR1 13937 MB/s
    Xeon X5550 2666 MHz Supermicro X8DTN+ i5520 Triple DDR3-1333 9-9-9-24 CR1 12472 MB/s
    Xeon X3430 2400 MHz Supermicro X8SIL-F i3420 Dual DDR3-1333 9-9-9-24 CR1 11598 MB/s
    Athlon64 X2 Black 6400+ 3200 MHz MSI K9N SLI Platinum nForce570SLI Dual DDR2-800 4-4-4-11 CR1 8855 MB/s
    Core i5 3600 MHz Asus P7P55D Deluxe P55 Dual DDR3-301 13-9-9-24 CR2 8344 MB/s
    Pentium EE 955 3466 MHz Intel D955XBK i955X Dual DDR2-667 4-4-4-11 8014 MB/s
    P4EE 3733 MHz Intel SE7230NH1LX iE7230 Dual DDR2-667 5-5-5-15 7893 MB/s
    Phenom II X4 Black 940 3000 MHz Asus M3N78-EM GeForce8300 Int. Ganged Dual DDR2-800 5-5-5-18 CR2 7659 MB/s
    Core 2 Extreme QX9650 3000 MHz Gigabyte GA-EP35C-DS3R P35 Dual DDR3-1066 8-8-8-20 CR2 7198 MB/s
    Core 2 Extreme X6800 2933 MHz Abit AB9 P965 Dual DDR2-800 5-5-5-18 CR2 7039 MB/s
    Core 2 Extreme QX6700 2666 MHz Intel D975XBX2 i975X Dual DDR2-667 5-5-5-15 6751 MB/s
    Memory Write
    CPU CPU Clock Motherboard Chipset Memory CL-RCD-RP-RAS Write Speed
    Core i7 Extreme 965 3333 MHz Asus P6T Deluxe X58 Triple DDR3-1333 9-9-9-24 CR1 12065 MB/s
    Xeon X3430 2400 MHz Supermicro X8SIL-F i3420 Dual DDR3-1333 9-9-9-24 CR1 9473 MB/s
    Athlon64 X2 Black 6400+ 3200 MHz MSI K9N SLI Platinum nForce570SLI Dual DDR2-800 4-4-4-11 CR1 8862 MB/s
    Core i5 3600 MHz Asus P7P55D Deluxe P55 Dual DDR3-301 13-9-9-24 CR2 7122 MB/s
    Core 2 Extreme QX9650 3000 MHz Gigabyte GA-EP35C-DS3R P35 Dual DDR3-1066 8-8-8-20 CR2 7088 MB/s
    Xeon E5462 2800 MHz Intel S5400SF i5400 Quad DDR2-640FB 5-5-5-15 6759 MB/s
    Xeon X5550 2666 MHz Supermicro X8DTN+ i5520 Triple DDR3-1333 9-9-9-24 CR1 6370 MB/s
    Phenom II X4 Black 940 3000 MHz Asus M3N78-EM GeForce8300 Int. Ganged Dual DDR2-800 5-5-5-18 CR2 5905 MB/s
    Athlon64 X2 4000+ 2100 MHz ASRock ALiveNF7G-HDready nForce7050-630a Int. Dual DDR2-700 5-5-5-18 CR2 5648 MB/s
    Memory Copy
    CPU CPU Clock Motherboard Chipset Memory CL-RCD-RP-RAS Copy Speed
    Core i7 Extreme 965 3333 MHz Asus P6T Deluxe X58 Triple DDR3-1333 9-9-9-24 CR1 14894 MB/s
    Xeon X3430 2400 MHz Supermicro X8SIL-F i3420 Dual DDR3-1333 9-9-9-24 CR1 12003 MB/s
    Xeon X5550 2666 MHz Supermicro X8DTN+ i5520 Triple DDR3-1333 9-9-9-24 CR1 9524 MB/s
    Core i5 3600 MHz Asus P7P55D Deluxe P55 Dual DDR3-301 13-9-9-24 CR2 8671 MB/s
    Phenom II X4 Black 940 3000 MHz Asus M3N78-EM GeForce8300 Int. Ganged Dual DDR2-800 5-5-5-18 CR2 8635 MB/s
    12x Opteron 2431 2400 MHz Supermicro H8DI3+-F SR5690 Unganged Dual DDR2-800R 6-6-6-18 CR1 7532 MB/s
    Athlon64 X2 Black 6400+ 3200 MHz MSI K9N SLI Platinum nForce570SLI Dual DDR2-800 4-4-4-11 CR1 7235 MB/s
    Opteron 2378 2400 MHz Tyan Thunder n3600R nForcePro-3600 Unganged Dual DDR2-800R 6-6-6-18 CR1 6992 MB/s
    Core 2 Extreme QX9650 3000 MHz Gigabyte GA-EP35C-DS3R P35 Dual DDR3-1066 8-8-8-20 CR2 6288 MB/s
    Memory Latency
    CPU CPU Clock Motherboard Chipset Memory CL-RCD-RP-RAS Latency
    Athlon64 X2 Black 6400+ 3200 MHz MSI K9N SLI Platinum nForce570SLI Dual DDR2-800 4-4-4-11 CR1 47.5 ns
    Athlon64 3200+ 2000 MHz ASRock 939S56-M SiS756 Dual DDR400 2.5-3-3-8 CR2 54.9 ns
    Xeon X3430 2400 MHz Supermicro X8SIL-F i3420 Dual DDR3-1333 9-9-9-24 CR1 57.5 ns
    Core i7 Extreme 965 3333 MHz Asus P6T Deluxe X58 Triple DDR3-1333 9-9-9-24 CR1 59.8 ns
    Sempron 2600+ 1600 MHz ASRock K8NF4G-SATA2 GeForce6100 Int. DDR400 SDRAM 2.5-3-3-8 CR2 60.6 ns
    Phenom II X4 Black 940 3000 MHz Asus M3N78-EM GeForce8300 Int. Ganged Dual DDR2-800 5-5-5-18 CR2 61.5 ns
    Athlon64 X2 4000+ 2100 MHz ASRock ALiveNF7G-HDready nForce7050-630a Int. Dual DDR2-700 5-5-5-18 CR2 61.9 ns
    Core 2 Extreme X6800 2933 MHz Abit AB9 P965 Dual DDR2-800 5-5-5-18 CR2 67.8 ns
    Xeon X5550 2666 MHz Supermicro X8DTN+ i5520 Triple DDR3-1333 9-9-9-24 CR1 68.7 ns
    Core i5 3600 MHz Asus P7P55D Deluxe P55 Dual DDR3-301 13-9-9-24 CR2 71.0 ns
    Core 2 Extreme QX6700 2666 MHz Intel D975XBX2 i975X Dual DDR2-667 5-5-5-15 71.5 ns
    Core 2 Extreme QX9650 3000 MHz Gigabyte GA-EP35C-DS3R P35 Dual DDR3-1066 8-8-8-20 CR2 74.9 ns
    Pentium EE 955 3466 MHz Intel D955XBK i955X Dual DDR2-667 4-4-4-11 80.2 ns
    Opteron 248 2200 MHz MSI K8T Master1-FAR K8T800 Dual DDR266R 2-3-3-6 CR1 80.6 ns
    Opteron HE 2210 1800 MHz Tyan Thunder h2000M BCM5785 Dual DDR2-600R 5-5-5-15 CR1 82.3 ns
    CPU Queen
    CPU CPU Clock Motherboard Chipset Memory CL-RCD-RP-RAS Score
    8x Xeon X5550 HT 2666 MHz Supermicro X8DTN+ i5520 Triple DDR3-1333 9-9-9-24 CR1 43713
    12x Opteron 2431 2400 MHz Supermicro H8DI3+-F SR5690 Unganged Dual DDR2-800R 6-6-6-18 CR1 43401
    4x Core i7 Extreme 965 HT 3333 MHz Asus P6T Deluxe X58 Triple DDR3-1333 9-9-9-24 CR1 30749
    8x Xeon E5462 2800 MHz Intel S5400SF i5400 Quad DDR2-640FB 5-5-5-15 30475
    8x Opteron 2378 2400 MHz Tyan Thunder n3600R nForcePro-3600 Unganged Dual DDR2-800R 6-6-6-18 CR1 22765
    4x Core 2 Extreme QX9650 3000 MHz Gigabyte GA-EP35C-DS3R P35 Dual DDR3-1066 8-8-8-20 CR2 21406
    2x Core i5 HT 3600 MHz Asus P7P55D Deluxe P55 Dual DDR3-301 13-9-9-24 CR2 21177
    8x Xeon L5320 1866 MHz Intel S5000VCL i5000V Dual DDR2-533FB 4-4-4-12 20506
    4x Core 2 Extreme QX6700 2666 MHz Intel D975XBX2 i975X Dual DDR2-667 5-5-5-15 19212
    4x Phenom II X4 Black 940 3000 MHz Asus M3N78-EM GeForce8300 Int. Ganged Dual DDR2-800 5-5-5-18 CR2 18632
    Xeon X3430 2400 MHz Supermicro X8SIL-F i3420 Dual DDR3-1333 9-9-9-24 CR1 17914
    4x Xeon 5140 2333 MHz Intel S5000VSA i5000V Dual DDR2-667FB 5-5-5-15 16740
    CPU PhotoWorxx
    8x Xeon X5550 HT 2666 MHz Supermicro X8DTN+ i5520 Triple DDR3-1333 9-9-9-24 CR1 51978
    12x Opteron 2431 2400 MHz Supermicro H8DI3+-F SR5690 Unganged Dual DDR2-800R 6-6-6-18 CR1 47029
    4x Core i7 Extreme 965 HT 3333 MHz Asus P6T Deluxe X58 Triple DDR3-1333 9-9-9-24 CR1 39236
    8x Opteron 2378 2400 MHz Tyan Thunder n3600R nForcePro-3600 Unganged Dual DDR2-800R 6-6-6-18 CR1 29372
    Xeon X3430 2400 MHz Supermicro X8SIL-F i3420 Dual DDR3-1333 9-9-9-24 CR1 28036
    8x Xeon E5462 2800 MHz Intel S5400SF i5400 Quad DDR2-640FB 5-5-5-15 24103
    2x Core i5 HT 3600 MHz Asus P7P55D Deluxe P55 Dual DDR3-301 13-9-9-24 CR2 22844
    4x Phenom II X4 Black 940 3000 MHz Asus M3N78-EM GeForce8300 Int. Ganged Dual DDR2-800 5-5-5-18 CR2 19654
    4x Core 2 Extreme QX9650 3000 MHz Gigabyte GA-EP35C-DS3R P35 Dual DDR3-1066 8-8-8-20 CR2 18275
    2x Core 2 Extreme X6800 2933 MHz Abit AB9 P965 Dual DDR2-800 5-5-5-18 CR2 14160
    4x Core 2 Extreme QX6700 2666 MHz Intel D975XBX2 i975X Dual DDR2-667 5-5-5-15 11697
    CPU ZLib
    12x Opteron 2431 2400 MHz Supermicro H8DI3+-F SR5690 Unganged Dual DDR2-800R 6-6-6-18 CR1 186166 KB/s
    8x Xeon X5550 HT 2666 MHz Supermicro X8DTN+ i5520 Triple DDR3-1333 9-9-9-24 CR1 176510 KB/s
    8x Xeon E5462 2800 MHz Intel S5400SF i5400 Quad DDR2-640FB 5-5-5-15 140055 KB/s
    8x Opteron 2378 2400 MHz Tyan Thunder n3600R nForcePro-3600 Unganged Dual DDR2-800R 6-6-6-18 CR1 124842 KB/s
    4x Core i7 Extreme 965 HT 3333 MHz Asus P6T Deluxe X58 Triple DDR3-1333 9-9-9-24 CR1 111618 KB/s
    8x Xeon L5320 1866 MHz Intel S5000VCL i5000V Dual DDR2-533FB 4-4-4-12 96502 KB/s
    8x Opteron HE 2344 1700 MHz Supermicro H8DME-2 nForcePro-3600 Unganged Dual DDR2-667R 5-5-5-15 CR1 90101 KB/s
    4x Phenom II X4 Black 940 3000 MHz Asus M3N78-EM GeForce8300 Int. Ganged Dual DDR2-800 5-5-5-18 CR2 79105 KB/s
    4x Core 2 Extreme QX9650 3000 MHz Gigabyte GA-EP35C-DS3R P35 Dual DDR3-1066 8-8-8-20 CR2 77575 KB/s
    4x Core 2 Extreme QX6700 2666 MHz Intel D975XBX2 i975X Dual DDR2-667 5-5-5-15 70530 KB/s
    4x Xeon 5140 2333 MHz Intel S5000VSA i5000V Dual DDR2-667FB 5-5-5-15 61460 KB/s
    4x Phenom X4 9500 2200 MHz Asus M3A AMD770 Ganged Dual DDR2-800 5-5-5-18 CR2 58747 KB/s
    Xeon X3430 2400 MHz Supermicro X8SIL-F i3420 Dual DDR3-1333 9-9-9-24 CR1 58577 KB/s
    2x Core i5 HT 3600 MHz Asus P7P55D Deluxe P55 Dual DDR3-301 13-9-9-24 CR2 57613 KB/s
    4x Opteron HE 2210 1800 MHz Tyan Thunder h2000M BCM5785 Dual DDR2-600R 5-5-5-15 CR1 42550 KB/s
    2x Core 2 Extreme X6800 2933 MHz Abit AB9 P965 Dual DDR2-800 5-5-5-18 CR2 39173 KB/s
    2x Athlon64 X2 Black 6400+ 3200 MHz MSI K9N SLI Platinum nForce570SLI Dual DDR2-800 4-4-4-11 CR1 38029 KB/s
    2x Pentium EE 955 HT 3466 MHz Intel D955XBK i955X Dual DDR2-667 4-4-4-11 29787 KB/s
    CPU AES
    2x Core i5 HT 3600 MHz Asus P7P55D Deluxe P55 Dual DDR3-301 13-9-9-24 CR2 226290
    12x Opteron 2431 2400 MHz Supermicro H8DI3+-F SR5690 Unganged Dual DDR2-800R 6-6-6-18 CR1 49041
    8x Xeon X5550 HT 2666 MHz Supermicro X8DTN+ i5520 Triple DDR3-1333 9-9-9-24 CR1 42606
    Nano L2200 1600 MHz VIA VB8001 CN896 Int. DDR2-667 SDRAM 5-5-5-12 CR2 41788
    8x Xeon E5462 2800 MHz Intel S5400SF i5400 Quad DDR2-640FB 5-5-5-15 41561
    8x Opteron 2378 2400 MHz Tyan Thunder n3600R nForcePro-3600 Unganged Dual DDR2-800R 6-6-6-18 CR1 32879
    8x Xeon L5320 1866 MHz Intel S5000VCL i5000V Dual DDR2-533FB 4-4-4-12 27703
    4x Core i7 Extreme 965 HT 3333 MHz Asus P6T Deluxe X58 Triple DDR3-1333 9-9-9-24 CR1 26616
    8x Opteron HE 2344 1700 MHz Supermicro H8DME-2 nForcePro-3600 Unganged Dual DDR2-667R 5-5-5-15 CR1 22868
    4x Core 2 Extreme QX9650 3000 MHz Gigabyte GA-EP35C-DS3R P35 Dual DDR3-1066 8-8-8-20 CR2 22411
    4x Phenom II X4 Black 940 3000 MHz Asus M3N78-EM GeForce8300 Int. Ganged Dual DDR2-800 5-5-5-18 CR2 21551
    4x Core 2 Extreme QX6700 2666 MHz Intel D975XBX2 i975X Dual DDR2-667 5-5-5-15 19923
    FPU Julia
    8x Xeon X5550 HT 2666 MHz Supermicro X8DTN+ i5520 Triple DDR3-1333 9-9-9-24 CR1 22014
    12x Opteron 2431 2400 MHz Supermicro H8DI3+-F SR5690 Unganged Dual DDR2-800R 6-6-6-18 CR1 19636
    8x Xeon E5462 2800 MHz Intel S5400SF i5400 Quad DDR2-640FB 5-5-5-15 19486
    4x Core i7 Extreme 965 HT 3333 MHz Asus P6T Deluxe X58 Triple DDR3-1333 9-9-9-24 CR1 14414
    8x Opteron 2378 2400 MHz Tyan Thunder n3600R nForcePro-3600 Unganged Dual DDR2-800R 6-6-6-18 CR1 13516
    8x Xeon L5320 1866 MHz Intel S5000VCL i5000V Dual DDR2-533FB 4-4-4-12 13158
    4x Core 2 Extreme QX9650 3000 MHz Gigabyte GA-EP35C-DS3R P35 Dual DDR3-1066 8-8-8-20 CR2 10986
    Xeon X3430 2400 MHz Supermicro X8SIL-F i3420 Dual DDR3-1333 9-9-9-24 CR1 9931
    4x Core 2 Extreme QX6700 2666 MHz Intel D975XBX2 i975X Dual DDR2-667 5-5-5-15 9831
    4x Phenom II X4 Black 940 3000 MHz Asus M3N78-EM GeForce8300 Int. Ganged Dual DDR2-800 5-5-5-18 CR2 8745
    4x Xeon 5140 2333 MHz Intel S5000VSA i5000V Dual DDR2-667FB 5-5-5-15 8593
    8x Opteron HE 2344 1700 MHz Supermicro H8DME-2 nForcePro-3600 Unganged Dual DDR2-667R 5-5-5-15 CR1 7980
    2x Core i5 HT 3600 MHz Asus P7P55D Deluxe P55 Dual DDR3-301 13-9-9-24 CR2 7743
    2x Core 2 Extreme X6800 2933 MHz Abit AB9 P965 Dual DDR2-800 5-5-5-18 CR2 5517
    4x Phenom X4 9500 2200 MHz Asus M3A AMD770 Ganged Dual DDR2-800 5-5-5-18 CR2 5329
    2x Core 2 Duo P8400 2266 MHz MSI MegaBook PR201 GM45 Int. Dual DDR2-667 5-5-5-15 4192
    2x Core 2 Duo T5600 1833 MHz Asus F3000Jc Notebook i945PM Dual DDR2-667 5-5-5-15 3402
    FPU Mandel
    8x Xeon X5550 HT 2666 MHz Supermicro X8DTN+ i5520 Triple DDR3-1333 9-9-9-24 CR1 11795
    12x Opteron 2431 2400 MHz Supermicro H8DI3+-F SR5690 Unganged Dual DDR2-800R 6-6-6-18 CR1 10991
    8x Xeon E5462 2800 MHz Intel S5400SF i5400 Quad DDR2-640FB 5-5-5-15 9772
    4x Core i7 Extreme 965 HT 3333 MHz Asus P6T Deluxe X58 Triple DDR3-1333 9-9-9-24 CR1 7829
    8x Opteron 2378 2400 MHz Tyan Thunder n3600R nForcePro-3600 Unganged Dual DDR2-800R 6-6-6-18 CR1 7667
    8x Xeon L5320 1866 MHz Intel S5000VCL i5000V Dual DDR2-533FB 4-4-4-12 6449
    4x Core 2 Extreme QX9650 3000 MHz Gigabyte GA-EP35C-DS3R P35 Dual DDR3-1066 8-8-8-20 CR2 5567
    8x Opteron HE 2344 1700 MHz Supermicro H8DME-2 nForcePro-3600 Unganged Dual DDR2-667R 5-5-5-15 CR1 5531
    Xeon X3430 2400 MHz Supermicro X8SIL-F i3420 Dual DDR3-1333 9-9-9-24 CR1 5210
    4x Phenom II X4 Black 940 3000 MHz Asus M3N78-EM GeForce8300 Int. Ganged Dual DDR2-800 5-5-5-18 CR2 5061
    4x Core 2 Extreme QX6700 2666 MHz Intel D975XBX2 i975X Dual DDR2-667 5-5-5-15 4848
    2x Core i5 HT 3600 MHz Asus P7P55D Deluxe P55 Dual DDR3-301 13-9-9-24 CR2 4339
    4x Xeon 5140 2333 MHz Intel S5000VSA i5000V Dual DDR2-667FB 5-5-5-15 4253
    4x Phenom X4 9500 2200 MHz Asus M3A AMD770 Ganged Dual DDR2-800 5-5-5-18 CR2 3750
    2x Core 2 Extreme X6800 2933 MHz Abit AB9 P965 Dual DDR2-800 5-5-5-18 CR2 2756
    2x Core 2 Duo P8400 2266 MHz MSI MegaBook PR201 GM45 Int. Dual DDR2-667 5-5-5-15 2149
    FPU SinJulia
    8x Xeon X5550 HT 2666 MHz Supermicro X8DTN+ i5520 Triple DDR3-1333 9-9-9-24 CR1 9533
    12x Opteron 2431 2400 MHz Supermicro H8DI3+-F SR5690 Unganged Dual DDR2-800R 6-6-6-18 CR1 6353
    4x Core i7 Extreme 965 HT 3333 MHz Asus P6T Deluxe X58 Triple DDR3-1333 9-9-9-24 CR1 6253
    8x Xeon E5462 2800 MHz Intel S5400SF i5400 Quad DDR2-640FB 5-5-5-15 5524
    8x Opteron 2378 2400 MHz Tyan Thunder n3600R nForcePro-3600 Unganged Dual DDR2-800R 6-6-6-18 CR1 4237
    8x Xeon L5320 1866 MHz Intel S5000VCL i5000V Dual DDR2-533FB 4-4-4-12 3484
    2x Core i5 HT 3600 MHz Asus P7P55D Deluxe P55 Dual DDR3-301 13-9-9-24 CR2 3373
    Xeon X3430 2400 MHz Supermicro X8SIL-F i3420 Dual DDR3-1333 9-9-9-24 CR1 3124
    8x Opteron HE 2344 1700 MHz Supermicro H8DME-2 nForcePro-3600 Unganged Dual DDR2-667R 5-5-5-15 CR1 2986
    4x Core 2 Extreme QX9650 3000 MHz Gigabyte GA-EP35C-DS3R P35 Dual DDR3-1066 8-8-8-20 CR2 2981
    4x Phenom II X4 Black 940 3000 MHz Asus M3N78-EM GeForce8300 Int. Ganged Dual DDR2-800 5-5-5-18 CR2 2619
    4x Core 2 Extreme QX6700 2666 MHz Intel D975XBX2 i975X Dual DDR2-667 5-5-5-15 2497
    Max cpu-z validation air
    [IMG]http://img535.imageshack.us/img535/7731/cpuzairvalidation.jpg[/IMG]
    Max B-CLOCK
    [IMG]http://img715.imageshack.us/img715/3094/maxbclock.jpg[/IMG]
    @ 2200mhz C 8-8-8-24
    [IMG]http://img192.imageshack.us/img192/7530/spi2200mhzram.jpg[/IMG]
    @ Sub 0 testing
    [IMG]http://img689.imageshack.us/img689/892/sdc10685d.jpg[/IMG]
    [IMG]http://img689.imageshack.us/img689/1556/wprimess.jpg[/IMG]
    [IMG]http://img192.imageshack.us/img192/1200/ln2.jpg[/IMG]
    [IMG]http://img188.imageshack.us/img188/2446/cpuzval.jpg[/IMG]
    Roundup:
    Pro's:
    Reaches high bclocks
    Turbo V remote
    High Dram clocks
    Solid stable power delivery
    Express Gate
    OV switches on cpu, vtt, dram
    Mem Ok
    Price
    Con's:
    Cannot handle high Bclock with 2:8 Mem divider
    Cannot handle high QPI frequency
    Cold Bug boot & Cold Bug -106c
    8x8 SLI, Crossfire
    Conclusion:
    This board is packed with features that will easily accomodate the enthusiast gamer with great overclockability
    and stability while keeping at a budget, supporting the latest i5 and i7 processors ( LGA 1156 ) and the capabilty
    of running ram up to 2200 mhz. While this is not the best board for extreme overclocking i would be giving
    this board a lot of consideration for a gaming rig.
    UNCLE FESTER
    Big thanks to Matt & ASUS support team
    Avatar von tAk
    Birsfelden, Schweiz
    5.058
    Great review an nice results there!
    Welcome @ AF.
    Greetings tAk
    Game: Core 7i 980x @ ?GHz | EVGA X58 Classified E762 | 6GB Corsair Dominator GT 2000C8 | 4 GTX 480 | Intel G2 80MB SSD & 2 500GB Samsung F1 + 1TB Samsung F1 | Win7 Professional | Dell U3011 | TT1500W
    04.03.2010
    25
    Thankyou tAK i just wish i could read and write german
