Ergebnis 1 bis 2 von 2
    04.03.2010
    25
    Standard RAMPAGE III EXTREME AIR REVIEW
    I recently received the new Rampage III Extreme motherboard from ASUS Australia, I had been eagerly awaiting this new motherboard ever since the first glimpses showed up on the internet.
    Overview
    http://img534.imageshack.us/img534/1341/sdc10779g.jpg
    http://img189.imageshack.us/img189/1821/sdc10780y.jpg
    http://img690.imageshack.us/img690/3807/sdc10792e.jpg
    http://img690.imageshack.us/img690/8591/sdc10786p.jpg
    http://img189.imageshack.us/img189/9773/sdc10787h.jpg
    http://img3.imageshack.us/img3/9307/sdc10785f.jpg
    I especially loved the active northbridge cooler such an improvement on past models, improves northbridge temps dramatically.
    Specifications
    CPU Intel® Socket 1366 Core™ i7 Processor Extreme Edition/Core™ i7 Processor
    Support Intel® Turbo Boost Technology
    Refer to www.asus.com for Intel CPU support list
    Chipset Intel® X58 / ICH10R
    System Bus Up to 6400 MT/s with QuickPath Interconnection
    Memory 6 x DIMM, Max. 24 GB, DDR3 2200(O.C.)/2133(O.C.)/2000(O.C.)/1800(O.C.)/1600/1333/1066 Non-ECC,Un-buffered Memory
    Triple channel memory architecture
    Supports Intel® Extreme Memory Profile (XMP)
    *Hyper DIMM support is subject to the physical characteristics of individual CPUs.
    *Refer to www.asus.com or this user manual for the Memory QVL (Qualified Vendors Lidts).
    Expansion Slots 4 x PCIe 2.0 x16 , support x16; x16/x16; x16/x8/x8 and x8/x8/x8/x8 configurations
    1 x PCIe x4
    1 x PCI 2.2
    Multi-GPU Support Support NVIDIA 3-Way SLI™ / ATI CrossFireX™ Technology
    4 PCIe x16 slots ready for 4 single PCB graphic cards
    Storage Intel ICH10R controller
    6 xSATA 3.0 Gb/s ports
    Intel Matrix Storage Technology Support RAID 0,1,5,10
    JMicron® JMB363 PATA and SATA controller
    1 xExternal SATA 3.0 Gb/s port (SATA On-the-Go)
    1 xSATA 3.0 Gb/s port
    Marvell® PCIe SATA 6Gb/s controller
    2 xSATA 6.0 Gb/s ports
    LAN Gigabit Intel® LAN
    Audio 8-Channel High Definition Audio CODEC
    - Blu-ray audio layer Content Protection
    - Supports Jack-Detection, Multi-streaming, Front Panel Jack-Retasking
    - Supports 1 Optical S/PDIF out port at back I/O
    IEEE 1394 2 x 1394a port(s) (1 port at back I/O, 1 port onboard)
    USB NEC® USB 3.0 controller
    - 2 x USB 3.0/2.0 ports (at back panel)
    Intel® ICH10R Southbridge
    - 9 x USB 2.0/1.1 ports (2 ports at midboard; 6 ports at back panel, 1 reserved for ROG Connect)
    Overclocking Features ROG Connect
    RC Bluetooth
    ROG Extreme Engine Digi+
    - 8-phase CPU power
    - 3-phase QPI/DRAM power
    - 3-phase NB power
    - 3-phase Memory power
    - ML Caps on CPU, Memory and QPI respectively
    ProbeIt
    iROG
    Extreme Tweaker
    BIOS Flashback with onboard switch button
    USB BIOS Flashback
    Loadline Calibration
    ROG Extreme OC kit
    LN2 Mode
    PCIe x16 Lane Switch
    Q_Reset
    Double Power Supply with dual 8-pin (CPU) and dual 4-pin (VGA) molex power connectors
    Intelligent overclocking tools:
    - ASUS AI Booster Utility
    - O.C Profile
    Overclocking Protection:
    - COP EX (Component Overheat Protection - EX)
    - Voltiminder LED
    - ASUS C.P.R.(CPU Parameter Recall)
    Special Features CPU Level Up
    MemOK!
    Onboard Switches: Power / Reset / Clr CMOS (at rear)
    ASUS MyLogo3
    ASUS Fan Xpert
    ASUS EZ Flash 2
    ASUS CrashFree BIOS 3
    Q-Fan Plus
    ROG BIOS Wallpaper
    ASUS Q-Connector
    ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
    ASUS Q-Slot
    ASUS Q-DIMM
    Back Panel I/O Ports 1 x PS/2 Keyboard port (purple)
    1 x Clr CMOS switch
    1 x Optical S/PDIF out port
    1 x IEEE 1394a connector
    1 x External SATA port
    1 x LAN (RJ45) port
    1 x ROG Connect On/Off switch
    1 x RC Bluetooth switch
    2 x USB 3.0/2.0 ports (Blue)
    7 x USB 2.0/1.1 ports (1 port also for ROG Connect)
    8-channel Audio I/O
    Internal I/O Connectors 1 x IEEE 1394a connector
    1 x S/PDIF Out connector
    8 x ProbeIt Measurement Points
    3 x Thermal sensor connectors
    1 x 24-pin ATX Power connector
    2 x 8-pin ATX 12V Power connectors
    1 x En/Dis-able Clr CMOS header
    1 x LN2 Mode Header
    1 x START (Power On) button
    1 x RESET button
    2 x EZ Plug connectors (4-pin Molex Power connectors)
    1 x OC Station header
    1 x RC Bluetooth header
    1 x Go Button
    1 x BIOS Switch button
    1 x ROG light connector
    1 x CD Audio in
    1 x Audio front panel
    1 x System panel connector
    1 x FAN1 Connector for optional fan-thermal module
    BIOS 16 Mb Flash ROM AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI2.0a Multi-Language BIOS
    Manageability WOL by PME,WOR by PME,PXE
    Accessories 1 x ROG Connect cable
    1 x ProbeIt cable set
    1 x 3-Way SLI Bridge
    1 x SLI Cable
    1 x CrossFire Cable
    1 x 2 in 1 ASUS Q-Connector Kit
    3 x 2-in-1 SATA signal cables
    1 x 2-in-1 SATA 6G cables
    1 x 2-port USB2.0 + ESATA module
    1 x I/O Shield
    1 x Thermal Sensor Cable Pack
    1 x Cable Ties Pack
    1 x ROG theme label
    1 x 12-in-1 ROG Cable Label
    1 x Optional Fan-Thermal Module
    1 x RC Bluetooth card
    Bluetooth Module Accessory Card
    Bluetooth V2.0/V2.1+EDR
    RC Bluetooth On/Off Switch
    Support Disc Drivers
    ASUS PC Probe II
    ASUS AI Suite
    ASUS Update
    Kaspersky® Anti-Virus
    Futuremark® 3DMark® Vantage Advanced Edition
    ASUS TurboV EVO Utility
    Form Factor ATX Form Factor
    12 inch x 10.6 inch ( 30.5 cm x 26.9 cm )
    Key Features
    RC BLUETOOTH:
    This new feature allows you to connect to your motherboard via a bluetooth connection, for overclocking and de-bugging your system.
    USB BIOS FLASHBACK:
    Extremely simple to use interface to flash your bios back should anything go wrong, simply place the R3E bio on your USB drive then place it into the ROG port and press the rog connect button for 3 seconds and it will automatically reload your bios for you.
    ROG CONNECT:
    Well by now we all know about ROG connect, the easiest way to overclock your system and do any de-bugging via your laptop, makes bios flashing and overclocking simple and safe.
    EXTREME ENGINE DIGI+:
    Asus extreme engine digi+ combines and take advantage of digital and analog VRM design ensuring the cleanest and most efficient power.
    Featuring duel 8 pin E-ATX 12v, aswell as 2 additional 4 pin molex connectors for extra gpu power.
    ROG EXTREME OC KIT:
    ASUS has really put some forward thought into extreme overclocking, allowing new items such as LN2 mode to try and eliminate cold bugging of the processor under extreme sub-0 temperatures.
    Test setup
    INTEL I7 980X EXTREME PROCESSOR
    RAMPAGE III EXTREME MAINBOARD
    CORSAIR DOMINATOR 2000 C7 3X2GB STICKS
    CORSAIR HX 1000 PSU
    ATI HD 5870 GPU
    OCZ VERTEX 64 GB SSD
    http://img3.imageshack.us/img3/2101/sdc10791d.jpg
    http://img690.imageshack.us/img690/415/screen001r.jpg
    http://img691.imageshack.us/img691/5742/screen021l.jpg
    http://img189.imageshack.us/img189/4221/screen004qa.jpg
    http://img690.imageshack.us/img690/2000/screen016y.jpg
    http://img685.imageshack.us/img685/6886/screen014x.jpg
    http://img189.imageshack.us/img189/184/screen013k.jpg
    http://img690.imageshack.us/img690/6582/screen012e.jpg
    Conclusions
    While i was not able to achieve a higher stable overclock on the factory heatsink provided with my i7 980x i found this to more than acceptable, these processors run really hot, during the wprime 1024 calculation my temps were only 2 degrees off of 100C. The board however ran seamlessly and i could not find anything wrong with it until i tested for max bclocks, i was surprised to find that max stable bclock was 220 anything over and things were unstable. This could be due to the fact i am using a very virgin bios and there are still some bugs to work out. I was very impressed when i was running super pi 1mg calculations and i just kept pushing the bclocks i managed to get the ram running at 2126mhz c7-8-7-20 with a northbridge frequency of 4787mhz.
    Pro's
    Looks awesome
    overclocks brilliantly
    bluetooth connect
    bios flashback
    ROG connect
    Active NB cooling
    low bclocks
    super pi efficiency is low
    STAY TUNED FOR SOME LN2 RESULTS
    BIG THANKS TO MATT & TEAM AT ASUS AUSTRALIA
    UNCLE FESTER.
    Geändert von SoF (09.05.2010 um 13:30 Uhr)
    Nice,
    please Pic´s 900x900
