    17.086
    Standard NVIDIA GTX 680 vs. GTX 580 in 03, 05, 06 and Vantage...
    Hey all,
    finally GTX 680 is here and I just made a quick comparison for the benchers among us.
    I just compared 580 to 680 in some "classical" benchmarks. It seems to be clear that old benches are screaming for Ivy while Unigine, Vantage and 11 are getting a nice increase already...
    content
    1. specifications
    2. impressions
    3. performance comparison GTX 580 vs. GTX 680
    4. software, bios and tools
    5. Extrem-OC information
    6. short summary
    1. specifications
    [IMG]http://www.awardfabrik.de/forum/attachment.php?attachmentid=5337&stc=1&d=1332764785[/IMG]
    2. impressions
    [IMG]http://img542.imageshack.us/img542/8415/dscf3593i.jpg[/IMG]
    Difficult to make a descision about clock by clock performance. yet the driver is very early.
    It seems in 03 and 05 (so most likely also 01) 580 GTX have better performance per clock.
    All tests without tweaks - no lod, no nspector settings, only performance-setting in the driver.
    heard d3d overrider doesn't work good in 03 with 301 driver...looses quite remarkable efficiency there.
    In 06 and Vantage things change and due to higher GPU clocks in general you see some increases. With higher CPU-MHZ you should see bigger differences but I don't have more time for now...
    ----------------------580 GTX--------------------------------------
    116633 - 3D Mark 2003 - GTX 580 900/1800/1100 MHZ (GPU, Shader, Speicher) - 295.73
    [IMG]http://img710.imageshack.us/img710/9206/03580gtx.th.jpg[/IMG]
    43127 - 3D Mark 2005 - GTX 580 900/1800/1100 MHZ (GPU, Shader, Speicher) - 295.73
    [IMG]http://img853.imageshack.us/img853/4483/05580gtx.th.jpg[/IMG]
    33179 - 3D Mark 2006 - GTX 580 900/1800/1100 MHZ (GPU, Shader, Speicher) - 295.73
    [IMG]http://img214.imageshack.us/img214/4594/06580gtx.th.jpg[/IMG]
    32047 - 3D Mark Vantage - GTX 580 952/1904/1100 MHZ (GPU, Shader, Speicher)
    [IMG]http://img843.imageshack.us/img843/9330/vantage32ks.th.jpg[/IMG]
    ----------------------680 GTX--------------------------------------
    111076 - 3D Mark 2003 - GTX 680 1109/1502 MHZ (GPU, Speicher) - 301.10
    [IMG]http://img209.imageshack.us/img209/4145/03680.th.jpg[/IMG]
    42842 - 3D Mark 2005 - GTX 680 1109/1502 MHZ (GPU, Speicher) - 301.10
    [IMG]http://img6.imageshack.us/img6/9378/05680.th.jpg[/IMG]
    33581 - 3D Mark 2006 -GTX 680 1109/1502 MHZ (GPU, Speicher) - 301.10
    [IMG]http://img545.imageshack.us/img545/732/06680.th.jpg[/IMG]
    35469 - 3D Mark Vantage - GTX 680 1216/1552 MHZ (GPU, Speicher) - 301.10
    [IMG]http://img827.imageshack.us/img827/2685/v680.th.jpg[/IMG]
    if you don't have them already, here are current drivers and tools:
    - GPUz 0.6.0
    - Nvidia 300.83 Beta Treiber WinXP 32bit
    - Nvidia 301.10 WHQL Treiber Vista / Win7 32bit
    - Nvidia 301.10 WHQL Treiber Vista / Win7 64bit
    - MSI Afterburner 2.2.0 BETA
    5. Extrem-OC Informationen
    Kingpin und Tin have already published everything the extreme-people need to know.
    very detailed information and absolut "must read" if you want to really wanna push 680 ref-design hard. thanks to vintin!
    complete VRM+Vmod-tutorial (caution: ADVANCED-MODDING!!!)
    3D Mark 2011 SingleGPU-WR by kingpin
    6. short summary
    Considering it is not yet the high-end card, it already leaves a good impression.
    Drivers might need some work and we need to figure out some new tweaks maybe but in Vantage and 11 it looks good already.
    If the bump from 680 to 780 (let's call it so for now) is as big as 480 to 580 it will dominate the same way.
    Reference cards seem to be weak on the VRM/PWM - hardcore modders definitly are in the lead here without proper custom-pcbz...
    regards
    SoF
    Avatar von oanvoanc
    18.02.2007
    wien
    315
    thanks for sharing.
    so do i get it right:
    mark: 580-680:
    03: 116k - 111k
    05: 43k - 42k
    06: 33k - 33k
    v: 32k - 35k
    hm... probably its the low resolution
    as the stock reference card is unable to bench under cold without mods, i hope, non ref cards will be more easy to mod/bench...
    17.086
    Yes you see it right - haven't checked if the 01 tweak still works with 680 but probably not with 301 driver.
    maybe things change a bit with very high cpu-clocks - ivy will show
